Old 01-21-2010, 03:22 PM   #14 (permalink)
alexander.foti
Carlos' point is also key: realize the ScanGauge reads in US gallons.
You can effectively change the MPG readings to display imperial gallons using the fuel offset if you want to.
I have read that if I tell i have a 10 gallon tank (uk gallons) and then input the first fuel adjustment in UK gallons then all other values will be in UK values.
Im not too bothered if the fillup adjustment factor only affect the miles to emtpy becuase I can ignore this knowing my avg and instant mpg values are accurate.
