wanna hear it, here it goes
Here you are S2,
But you gotta tell me where to get a *duino and some of the other stuff you men have been talking about.
I am working on the belief that your car has cruise. none of my info shows any other variant.
So,
Forgive me for not providing pics or diagrams, I will have to figure out how to get info from my garage computer to MY PC.
for a 1996 Cav. 2.2
The PCM is located under the front of the car, behind the bumper on the right [passenger] side.
Connector #1 Pin #10 is a black wire that feeds Injector #1
Connector #3 Pin #1 is a Dark green wire with a white tracer that feeds the pulses to the cruise. 4000 pulses per mile.
I chose that one because it feeds pulses at a fixed rate.
Connector #3 pins # 11&12 yellow & purple from the vss on trans feed variable alternating current, the vss on the trans is a small generator.
I will talk to my son [the CompuGeek] and see if i can network the two 'puters or carry info on one of those sticks he keeps in his pocket or what I need to do. I may have to put that puter on the web and just work from there.
Hope this helps,
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
