Old 03-23-2008, 12:58 AM   #118 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Thanks for the reply !
From looking at the picture of the spoiler bracket, it is slightly over-exposed so I can't tell what I'm really looking at. It looks as if there are two bolt holes where the light is located. Is that right ?
I'm thinking of just being a copy-cat ( you know the saying about imitation being the most sincere for of flattery ) with the tail light, except I will just try and add some length to the wiring so that I can use the stock light.
From what you have said about your car not overheating with no cooling what-so-ever, I think my engine must have other problems because the radiator often spills over into the overflow container.
Also, my oil seems darker than it should be for the few miles I have put on the car since I changed it last ( less than 1000 miles )
( I don't know a thing about cars and it really shows.)
Maybe I'm just overly paranoid.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
