Old 01-26-2010, 08:55 AM   #15 (permalink)
Old Tele man
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...unlike in art, a patina like that is definitely NOT something you want.
...some soaking in MacKay's Engine Cleaner will remove that gunk, but it'll also make all "wear" clearances/tolerances get bigger.
...lastly, the "top" compression ring might be a problem, because it rides right up against the "wear ring" in the cylinder -- installing a new ring with its new, unworn, 'square' ring edge will be "crunching" up against "the rounded" wear ring in the cylinder...and could result in a broken ring. MORAL: the top ring and cylinder bore cleanup are critical to longivity.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
