Thread: Belly pan soon
Old 01-27-2010, 12:14 AM   #10 (permalink)
ECONORAM
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by vtec-e View Post
Should be quiet enough if it is stiff enough. Any looseness and it will sound like thunder, if its anything like the alloy belly pan on on my old civic when i hit some bumpy sections.
Maybe some pre-stressing it into a slight curve before bolting on might help there?
And if you are trying to make an intake, make a naca type duct. Less drag and less like a weapon too!
Looking forward to pics and mpg gains.
ollie
That is about what I would suggest. If you have access to a sheet metal brake, you can bend a slight angle cati-corner and make an X in the sheet. This will help stiffen it a bit. If no brake, maybe find you a couple 2x4s, clamp them together, and bend it a bit that way...
The Following User Says Thank You to ECONORAM For This Useful Post:
dbracer23 (07-21-2011)
