Old 01-27-2010, 04:30 PM   #2 (permalink)
shovel
Starting mid-year in 2000, v6 equipped S10's began to get dual inline catalytic converters... the rear one stayed in the same location and is the same part number, but a new smaller one was added a couple feet forward, immediately after the junction of the two cylinder banks' exhaust.
This "precat" as it's called serves only one purpose: it heats up more quickly due to being closer to the engine and made of a lighter material - so it reduces HC emissions during the first few minutes of driving before the main cat gets up to temp.
"a guy I know" shattered the catalyst inside his precat after partially crushing the enclosure with a rock on a particularly rough Arizona road, removed it entirely & blew out the main cat with a leaf blower (to remove debris from the damaged precat) and filled the gap with a section of straight pipe. No driveability difference was apparent, the ECU did not report a post-cat O2 sensor failure, and the vehicle produced nearly identical #'s on its next emissions test.
YMMV.
2002 WJ Overland E85/gas flex
2002 Motobecane 700DS
1978 ChevroLegs
