Old 01-28-2010, 08:43 AM   #20 (permalink)
Gasoline Fumes
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
The XFi piston places its single compression ring in a slightly different location than the top ring on the normal piston. I don't know if that's significant or not. The XFi and standard top rings are the same size, but only the XFi has the special "gapless"design. I don't see why you couldn't give the standard pistons the XFi treatment. Maybe the extra/open ring groove will collect goo and keep the other rings cleaner.
Another view of the special gap. Same ring, just flipped for the second pic.
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
MetroMPG (01-28-2010)
