Old 01-29-2010, 10:07 AM   #7 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
In case some you don't understand that people are mocking this idea, it is because with an alternator driven by a belt the belt is the loss, with an alternator turned by the air the air is being used as a working fluid to turn the alternator and fluid drives are not very efficient, at best on average you can get around 50% of the energy out of the air as anything more and it tends to go around the blades.
Originally Posted by theycallmeebryan View Post
Regardless if you are using the engine or propellers to turn the alternator, you will still have to use extra power to do it.
