Old 01-29-2010, 02:57 PM   #4 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
thatguitarguy -
Originally Posted by thatguitarguy View Post
Will it still take a minute if you have to turn you key to start the car at the end of an EOC?
No. Once the engine is warm it takes less than 10 seconds. Sometimes less than 5. I think it goes to closed loop fast when the engine is warm. The ECU/PCM probably looks at the coolant temperature.
If closed loop does look at the coolant temperature, you could probably fool the ECU/PCM into faster closed loop operation by spoofing the coolant temperature sensor. The bad thing about this is the implication (but not the fact) that you could hurt your engine at warm-up. I think you would definitely harm your emissions.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
thatguitarguy (01-29-2010)
