That response is sure all over the place. He says that RR makes almost no difference to MPG (HA!) and then goes on to say that inflation pressures make a big difference in MPG.??!?
Most Nokians are LRR. I have WRG2 on my Prius and they are excellent. The i3s and the H are both LRR, the H being the lower. They use a silica/canola oil compound. The H also
recently won a
European auto club test. Also they are non toxic since 2004. All this and cheaper than Michelins.
They used to have an NRT2 tire with a measured RR of .0085. It came in #2 in the green seal report if I remember correctly. Don't know what their tires measure in at now but I bet they are similar. I looked at the B381 but the traction rating of B is just not good enough to justify the .0065 RR
You can get them at tire factory.
