Make sure your t-stat is good, a cooler running efi engine will use more gas than a hot (190* temp) running one. What kind of vacuum is the engine making at idle & is the needle steady? Check fuel pressure & make sure it holds pressure w/ the engine off. Are you using a block heater for quicker warm ups?
