Thread: MAF sensor life
Old 03-24-2008, 04:03 PM   #1 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
MAF sensor life
What are you guy's experience with mass airflow sensors? My Matrix is the first vehicle that I have owned with a maf sensor. This winter, on a very cold day, it started real rough and threw the check engine light on. It ran fine once warmed up I pulled the code with my scangauge and it said it was a maf sensor malfunction. I let it go knowing that the car uses the maf sensor literally around 2% of your driving time as its in closed loop 98% of the time. The check engine light went out later that day or so. This same thing happened about three times during winter and hasn't happened in the last two months. I did clean the sensor with cleaner after the first time it happened and that seemed to help a little. But, it came back on a few weeks later. So, I don't think its that. My question is, do maf sensors wear out (I didn't think they did)? If I'm looking to replace it should I get a salvage yard sensor, or a new one?
edit: is there anyway to edit the title after posting?
