Another good way to lube your cables is to unhook the top end of the cable, poke it through a ziplock bag, tape up around the hole for no leaks, put some oil into the bag, set it & forget it!
The oil will slowly seep through the line. When doing your brake lines you can pump the brake a bit too.
S.
