Old 02-04-2010, 10:38 PM   #8 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Guys, did Suzuki use these rings in any of their engines?
What are the odds of being able to take a bigger (1mm or so) ring and filing it at a steep angle to approximate the gapless design?
If the XFi's rings are 74mm, rings from D-series engines (Honda) should work... they're 75mm pistons.
I'm not sure if it would work or not, but NPR sells Honda D series rings cheap enough that it might be worth it to try.
Will, I've got some old D-series rings still on pistons, maybe. I could send a couple to each of you if I can find them, and that way you could both work on trying to make a gapless ring from a slightly larger one?
Thinking about it, I may not have those rings. I'll have to take a look the next time I'm at my Father's house before I offer them.
