Old 02-06-2010, 12:48 AM   #17 (permalink)
ChrstphrR
Greta - '00 Jetta TDI
90 day: 59.96 mpg (US)
Send a message via Skype™ to ChrstphrR
Originally Posted by RobertSmalls View Post
And, this picture has me wondering where the stagnation point is on a stock car, and on one with a grille block. Do I want to send air over the car where there's more room for air, or under the car to fill the vacuum under the tail?
You want to send most of the air over the top, and around the sides (like what aerohead usually extolls, and Basjoos mentioned in his post too.
For the most part, you wouldn't want a LARGE increase in airflow under the car, or it may have an unsettling lifting body effect, which could affect handling at highway speeds or higher. Not that this is likely to happen with the shape of the Insight's nose; but it was an issue with the Stingray Corvettes of the mid-60s.
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
The Following User Says Thank You to ChrstphrR For This Useful Post:
aerohead (02-06-2010)
