Old 02-06-2010, 03:28 AM   #6 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Originally Posted by Christ View Post
Can you take some percent of your fuel pellets and soak them in the oils, then mix them back in with the bulk before delivery to the stove? That way, you're not introducing liquid fuels at all.
I have done that with greasy dogfood (aka mix with pellets) to prevent jams
However the amount of pellets to soaked pellets would likely not allow a significant amount of oil to be used, likely only ounces per 40lb since pellets don't really absorb anything and if they do they fall apart.
The pellet stove insides are blocked off like a blast furnace with a sealed door so I don't see how I would end up with out of control flames, even if it burned up the fill pipe it would be such a small opening the flame would loose O2
