Thread: Howdy
Old 12-07-2007, 03:04 PM   #10 (permalink)
diamondlarry
EPA MPG #'s Slayer
diamondlarry's Avatar
La Forge - '07 Prius
90 day: 84.38 mpg (US)
DOHCtor Green MPG - '99 SL2
90 day: 49.17 mpg (US)
Silver Sipper - '00 Insight
Originally Posted by Lazarus View Post
Welcome aboard good to have you around. Great numbers with the Prius. How's the WAI working for your numbers and how did you set it up?
I used some flexible tubing that would be used for the old carb heater setup. I just disconnected the stock air hose and slipped the tubing on then routed it over the top of the engine and directed it toward the exhaust manifold.
As for the numbers, this is the first year I've had the car in winter weather so I don't have any accurate way to compare. The tubing cost about $8 so if it isn't doing any good I'm not out a bunch of $'s.
