Originally Posted by luvit
hey, uh, do i have to worry about the tranny filter getting filled/plugged?
my tranny filter is inside the tranny.. unaccessible. lol.
Should have changed the filter at the same time as the fluid, really.
If your transmission starts acting funny, drop the pan, run the fluid through a strainer/filter (T-shirt in a collander) and you can reuse it with a new filter, as long as it's still pinkish red. If it's discolored, or has a burnt smell, discard and install new fluid. This time, check to see if your torque converter has a drain plug.
