Old 02-09-2010, 02:03 AM   #2949 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
I ordered 24 of those new fancy TO-264 230amp 200v mosfets today.
Fancy Mosfets!
The sixteen 1000uF capacitors and new LEM (8 pin surface mount) will ship on the 14th. I'm torn between 2 drivers or 1 for each of the high and low side. I think 1 driver would be OK if I lowered the gate resistance just a bit. It's a 12amp driver, and I've only been using like
I also just won a Fluke 337 amp meter so calibrating the new LEM will be easier. I think I'm going to try Darin's metal coat hanger method of drawing like 50 amps from a battery to calibrate it.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
The Following User Says Thank You to MPaulHolmes For This Useful Post:
deodeo (03-23-2012)
