Old 02-09-2010, 02:33 AM   #14 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Lugging an Automatic
So, I have modified the automatic to lockup the Torque Converter at the flick of a switch -- if started in 2nd, it has been possible to stall the engine and override the ECU/TCU.
With that said, I have wondered the same about lugging. Typically, I can get the revs down to 1100, which maxes engine load and has been noted to warm-up the vehicle quicker than slipping with the slush (or even lower with 2nd-gear start). The best feature is the throttle lift-shift that generally produces more of a vibration than "lug". To engage full lockup, it requires significant throttle input -- which is a give-and-take. Transmission warmup is faster as well.
FE has improved with the mod, but with Winter, the percentage is hard to estimate. The benefit of essentially having a "heavy manual" is nice.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
