Old 03-25-2008, 01:22 PM   #2 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I'd look at your engine grounds and see what kinda corrosion you have going on. That could explain the voltage drop. When you put your connections back together make sure to use some dielectric grease (aka bulb grease) so they won't corrode again.
Also, welcome to the site.
