Old 02-09-2010, 12:17 PM   #17 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
So the concensus seems to be: it's OK to cruise at low RPM and low load.
If you need more power, you should downshift if:
1) the engine lugs (shudders) when you push the accelerator further, or
2) you cause the engine to go into open loop (typically at very high loads - ie. pedal near the floor), which can be monitored with a ScanGauge
