Old 02-10-2010, 07:15 AM   #23 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
Originally Posted by luvit View Post
thanks.
i may be too lazy for all that. what if i just get a regualar trans flush every 3k miles with my oil change 2 or 3 times? lol.
The easy way would be to just drain and refill...replacing about 1/2 the fluid say 2Xs per year. But you should drop the pan...clean it and replace the filter. All the grit and metal particles will be in the pan...and some trans have actual filters instead of screens. You'd need a Haynes manual to do it right.
Might also stick a neo magnet on the bottom of the pan to help catch some steel?
When I did my Nissan...I'm fairly sure it was the original oil in it...it was brownish instead of red. If you tested it vs new ATF between thumb and forefinger...you could tell it had less lubricity....no slicky...slicky.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
