Originally Posted by MetroMPG
If that line does show torque at WOT, that may make it incredibly useful: could you not essentially use it to extrapolate what throttle/pedal position to use to get the engine closest to the sweet spot at a given RPM?
EG. in the Saturn chart, 7/9 throttle @ 2000 RPM looks like it would put you squarely in the 250 g/kWh island.
That's what I was trying to say in the shift timing thread. 7/9 = 77% of max torque (or load). Examining a bunch BSFC maps, and measuring the extents and center of the peak efficiency island, I found the
average center point to be 72% of max load. Hence the question; Can we believe the LOD output on the
scangauge as a good indication of engine load?
