The Electrac did marginally better because of all the battery weight.
A little ballast would have likely cured your problem. This is why tractors use liquid in their tires, wheel weights, and chassis weights.
Of course, in a low-friction mushy environment, the wheels must be wide in order to not sink into the medium.
