Old 03-25-2008, 07:30 PM   #1 (permalink)
tasdrouille
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Misc pumping losses questions
I have a couple questions in regards to intake flow and resulting pumping losses.
Anyone knows why the throttle is typically a butterfly valve? I clearly remember from Hucho's book that a gate valve has a significantly smaller impact on the flow. Why don't we see throttle bodies equiped with gate valves? (or maybe I should just look at more cars..)
Also, I was always told that what had the most impact on pumping losses was the throttle plate, but now I read that CVVT can reduce pumping losses at light loads by 80%, so it looks like the valves timing would be the main culprit, no? I'm a bit confused.
www.HyperKilometreur.com - Quand chaque goutte compte...
