...as I understand it, Manifold Air Pressure (MAP) and Mass Air Flow (MAF) basically tell you how "deeply" the engine is breathing in air, MAP by differential pressure (intake vs. outside air) and MAF by "how much" air is being sucked (breathed) in.
...hence, in my mind, they're fancy vacuum gauges, with MAP being most like a vacuum gauge. MAF is "mass" based rather than "pressure" based.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
