Old 02-13-2010, 12:13 PM   #73 (permalink)
Grim
Having lost a wheel that I torqued properly with a torque wrench I later found it was my own stupidity that I didn't clean the mating surface on the hub.
There was surface rust on the face of the brake drom and when I changed the wheel to a different style the rust was under the mating surface of the new wheel. It powdered causing a loss of torque on the lug nuts as I was driving. Lost the 35 inch wheel 95lb wheel assembly on a 6,000lb jacked up K5 Jimmy at 60mph. The wheel rolled down through the median through oncoming traffic hit a curb that launched it about 20ft in the air and when it came back down it slammed into the passenger side door of a Ford ranger that was stopped at the cross street. Thankfully nobody was injured but it did $1800 damage to a truck with $2000 fair market value.
Wire brush wheel on the drill would have prevented it.
Cool read
I have a little 4x6 enclosed cargo trailer that I camp out of I am trying to figure out how to stream line behind both my 4runner and my Previa and a lot of ideas that you have posted will help. The roof height is dead even with the 4Runner when hitched so I have that going for me. The Previa is close to the same overall hight.
It is raised so I can pull it off road but I think an adjustable tongue so I can pull it up tight to the trucks on the hwy and some sort of boat tail on the rear door will help. Maybe a Kamm style tail on the trucks to take up some of the gap.
Look forward to the next updates.
The Following User Says Thank You to Grim For This Useful Post:
aerohead (02-13-2010)
