Old 02-14-2010, 09:36 AM   #2966 (permalink)
jackbauer
jackbauer's Avatar
Yeh it works great thanks. I'd just like a little delay (say 5 seconds) between throttle going to zero and the pin going low. Just saves wear on the contactor. Also in a failed power section situation I'd rely on the shunt field to stop the motor overspeeding.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
