Dave , yeh paul has sent me over a new hex file. The purpose of this setup is not to control the main contactor but the power to the shunt field section of my compound motor. It takes about 4 amps at 72v so no point having it on when sitting in traffic etc. I needed a delay on the turn off to stop the contactor jumping in and out when using light throttle and in the event of a controller failure the shunt field will stop the motor from overspeeding and give me a chance to turn the key off.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
