Old 02-15-2010, 02:09 PM   #19 (permalink)
bgd73
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
Originally Posted by TOOSTUBBORN2FAIL View Post
this is something i will be doing with my neon as well, also from total seal, as recommended by a professional road racer and inside source from chrysler.
Benifits for my 3 ring set up is almost 100 percent seal from the top ring, allowing lower ring tension on the secondary ring, allowing more power (and efficiency), and less friction.
ggpless is for small four strokes, leaving oe compression alone (gaskets, stock heads)
a neon of all vibrating crazy hemi sized sucking inline fours is making for an explosively short lifed engine. Just helping out here,
I built a bit of every engine..
I do not know as I would even put it on a 600 cc two stroke. Stuff starts getting much bigger in the 1.8L+ fours
that is a serious move. and you geo owners. for god sakes..remove egr before doing it?
