Originally Posted by Christ
If the large ones are still slightly too small, you might try stacking two small ones in the ring land instead? That would negate having to make the gapless rings altogether, since you could "clock" the gaps at 180* to each other. I'm sure that's just one of my hare-brained ideas, though.
Initially this sounded like a great idea, especially if the honda rings are thin enough such that two of the stack up to the thickness of one stock xfi ring. Again, I'm a beginner at this, so I'm not really in a great position to say what would work and what wouldn't, so here's the only thing I could think of that may or may not cause problems when putting two rings into one
land as you call them (new term for me): If there is even a teeny gap in the top ring, carbon may build up on the lower ring just below the gap and potentially cause enough buildup to raise that side of the top ring, skewing its formerly level position and causing uneven wear on the cylinder walls. I don't know if this could or would happen, but this could actually be a brilliant inexpensive solution for people trying to find a gapless ring solution to rebuild an XFi motor...That's really what this thread is about - sourcing a cheap gapless solution. When I made the thread, I was thinking totalseal was the only remaining solution. The jury is still out.
