Old 02-17-2010, 11:30 AM   #29 (permalink)
Gasoline Fumes
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
If you have an EGR, it would be bolted to the right side of the intake manifold. I believe the '92+ G10s all had it, I'm not sure about the older ones. I know the 1989-91 G13B did not have EGR outside of California.
Stacking two rings in interesting for a gapless setup, but is it better than using the non-XFi pistons as far as friction is concerned? The oil ring rails are pretty thin if a "shim" is needed. 0.47mm on my NPR set.
