Old 03-26-2008, 11:30 AM   #4 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Yeah, pretty much just a bolt with a wire going to it. Just look for wires that go from the engine to the chassis. If you want, you can measure the resistance between the negative post of the battery and the engine block/head. That should give you a good idea of how bad things are.
