Foam clearing
Just a suggestion for the getting rid of your foam form, acetone. I build tons of things out of foam, both as final pieces and as forms. The acetone shouldn't hurt the skin of your project, it might even clean off excess binder if you used resin. WEAR A RESPIRATOR, this stuff is very bad and do it outside. Also you might want to warn the neighbors too.
