Old 02-22-2010, 07:53 PM   #11 (permalink)
Lazarus
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
Well the Fusion is kind of a sled. It could definitely use a belly pan, block heater and a grill block. I think it has great potential especially if you had a SG attached. Very solid ride. With the 6th gear auto the engine RPM is around 1750 at 60 MPH.
The TCU is learning my driving style and will now shift at 2000 rpm. The shift point are about 3-5 mph higher then I'm used to with an automatic but will let the MPH drop about 7 MPH before down shifting.
I picked it up yesterday and drove it 25 miles to the house. 38.3 MPG from a cold start. It was a perfect day with a light wind and 75 degrees. Did not get a chance to put air in the tires. They are rated at 51 PSI but only have 36 PSI in them. Left early this morning with temperature around 43 degrees. Lost about 3.6 MPG before the engine ever warmed up enough to reverse the downward trend. When I pulled into the chocks today it was reading 39.3 MPG.
From here the MPG will plummet. I have 4 days of 5 miles of gridlock to attack each way and the temps are suppose to be highs in the 30's with rain/snow. As slow as this thing warms up it will not be to temp before I get to destination. More to come....
"Judge a person by their questions rather than their answers."
