Old 03-26-2008, 08:18 PM   #121 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
The easiest WAI ever!
So, after reading Hondaworkshops thread, I decided today was a pretty good day try out the warm air intake (hereafter referred to as WAI) that I've been scheming about for a few weeks.
Knowing that there is at least part of the intake coming from inside the engine compartment (about 1 foot from the header) I convinced myself that Honda wouldn't have possibly made it that easy to do a WAI.
"Surely," I thought, "there must be another intake point in the resonator somewhere crammed into the front bumper under the passenger headlight."
So, intakes were dissassembled, bumpers were partially pried off, but no other source of intake air was found.
"Surely," I thought, "Honda couldn't have made it that easy. That second intake point must be SOMEWHERE back there where I can't reach it!"
The heavy artillery was called in.
I hooked up the shop-vac to the intake, stuffed all the known holes with rags, then I flipped the switch.
Technically, I was right.
Honda did leave another point for intake air to enter the resonator. And when I say "point" I really mean it. It's a drain-hole in the bottom of the resonator in the bumper, about 1/8" in diameter. Not even worth bothering with.
30 minutes of dirty work all to find out that Honda actually did make it that easy to make a WAI. /
So, what is neccessary for the worlds easiest WAI, you ask?
One 18" length of 3" aluminum vent hose.
One zip tie.
And one ~12" piece of wire.
Slip the vent hose over the intake "port" (or whatever you want to call it), zip tie the vent hose in place.
Stretch the end of the vent hose up in-between your header and catalytic converter, use your piece of wire to hold it in place.
I illicitly "borrowed" my wifes digital probe thermometer from the kitchen and hooked it up to the intake of my car, just above the air filter and ran a little before and after test.
Before the WAI, intake temps varied from 65º to 85º, getting steadily cooler at higher speeds.
After the WAI, intake temps were around 140º in town and varied from 120º to 180º on the highway.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
