eco truck 2000 pounds, haha. sick joke.
if one existed, I'd make it a goal to have it.
the little s10 four cyl is a dud, you may hurt yourself with 500 pounds..better off with the escort at 88hp.
the 4.3 s15 could work, but crank is built lopsided, not a heavy hauler. 1 ton has its weight on the drivetrain.
you could go overseas and find an austrailian petrified turbo hilux, but that may get expensive. the rest of the toyotas are bent broke.
Hmmm.
there is a horse with a cart that could it...
subarus can too, just check the bodies first, must be in good shape or welded. in fact, that is the modern day marvel.
my dad has a tracker with 2 liter, just dump trips with trailer are taking a toll, much less than 2k pounds..and that is full bodied and framed.makes little Trucks seem even sillier...
a sensitive subject.
