Old 03-04-2010, 05:53 AM   #9 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
Polyisobutylene is a synthetic rubber used in some 2 cycle oils for it's lubricity and because it can control the burn...also used in jet fuel to reduce fire dangers.
Also tested as a fuel additive to possibly increase mpg.
Silicone caulk is a synthetic rubber? I'd be maybe scared sheetless to use it in a trans...but I know of people who use straight boric acid in trans...so no biggie?
I've heard of the use of Restore additive used in a trans....
Vehicle : 1980 Honda Accord w/ 100k miles
I drove my 1980 Accord from about 90,000 miles on. It was 12 years old when I bought it and ran until I drove it into the ground years later. I used Restore in the engine oil and got noticeable, dramatic improvements in horsepower and gas mileage. What I didn't expect was to have Restore save my manual transmission... Somewhere around 100k, the 5-speed manual transmission started making a horrible low-pitched grinding noise whenever it was in gear. The noise was loud and unsettling and got louder with higher speed... I knew it was probably a bearing and it wasn't worth getting a $700 tranny job on a $300 car. So, in a last-ditch effort to squeeze a little more life out of the poor thing, I added a small (4-cylinder sized) can of Restore to the manual transmission oil... I was ASTOUNDED when - in about 300 miles - the grinding noise started to fade. After a month and about 500 miles, it was COMPLETELY GONE! I never heard another peep out of the transmission! I wouldn't recommend this to anyone unless they have no other options (I looked, and Restore does not recommend their product in manual transmissions), but Restore did completely fix a worn-out, dying manual transmission in a 16-year-old Honda. If it can do that, think of what it can do for worn rings and mainshaft bearings. Chris N "
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
The Following User Says Thank You to suspectnumber961 For This Useful Post:
bgd73 (03-04-2010)
