Old 12-08-2007, 01:43 AM   #8 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Block Heater
The EBH can be a great alternate to a heated garage...
If you have a 110V plug and extension cord, I would say that it's worth it to get the vehicle to up to temp sooner.
Compared with a dead-soak, cold start vs. an indoor or outdoor EBH startup, the block heater gets the system up to efficient operating temp much sooner than otherwise -- including the time to automatic transmission torque converter lockup. That translates to fuel savings...
-RH77
Edit: depending on the climate and outdoor temp, a timer may be appropriate to time the EBH heat-up duration...
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
