Old 03-05-2010, 05:01 PM   #13 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
I've used it before...it's a chlorinated hydrocarbon??? One recommended use is to mix it with axle grease to reduce bearing drag.
They use it in engines..gearboxes...gun bores.
I did use it once to lube a vacuum cleaner bearing that squealed...nothing stopped it till I mixed some Militec in with some grease.
Smells like rancid oil.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
