Originally Posted by aerohead
I've had success using Elmer's Glue and also polyurethane as a barrier coat on Styrofoam before glassing with polyester resin.
Hi Aerohead,
How about taking this a step further to save more cost...
Instead of using Elmer's glue as a barrier, why just use the same glue to hold on the fiberglass itself, as in this example (about 3/4 down the page).
Honda Insight Under-body Smoothing Panels (custom belly pan / undertray)
It's lasted over 15 years so far, as still looks good!!
Might just use the same technique on the tail extension. You never know!!
Jim.
