Old 03-06-2010, 11:54 PM   #59 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Originally Posted by orange4boy View Post
No. For now it's manual but that would be a plan for later. Do you know of something readymade?
Uh, no, I would build one from my 'junk box.'
Specifications:
  • zener reference voltage
  • setable "cut out" voltage - trim resistor adjusts the cut out, once set, the battery is disconnected
  • setable "engage" voltage - second trim resistor adjusts the higher, enable voltage so the battery voltage rise from no load won't trigger oscillation.
  • enable line - tied to ignition, it enables the deep storage battery. Breaking enable line, disconnects the deep storage relay.
  • diode protected relay engage drive - (old school), optional MOSFETs
Actually it would be more fun to build an integrated system that includes the charger and a buck regulator to . . . <GACK> stop NOW!
Bob Wilson
Local record
