Old 03-07-2010, 01:14 AM   #2 (permalink)
redline5th
Honda Ecomodder
redline5th's Avatar
The Civic - '98 Civic DX
90 day: 41.59 mpg (US)
Catalytic converter can have a terrible effect on the performance and fuel economy... I would check that.
I would also check the basics.... air filter, fuel filter, plugs, wires, cap/rotor (assuming it has a distributor), make sure your brakes aren't hanging (do the wheels spin freely?), does the throttle body test to see if the butterfly is opening all the way.
It could be a sensor of some sort.
Hope this helps!
http://thechriscoleman.com/
Alas.... no more 40mpg -- Now B18C swapped.
The Following User Says Thank You to redline5th For This Useful Post:
Cincyguy (03-07-2010)
