Old 03-08-2010, 07:10 AM   #17 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
Here is something from mpgresearch.com....
85 22R Toyota carbed ...96 HP....85 EFI....116 HP
I've been making the same effort with my '88 Toyota
4wd 5speed with 222K miles and I manage between 27.5
and 29.7mpg. This includes some city driving, perhaps
25%, and some hauling, perhaps 15% of the time and up
to ~ 3/4 ton in the back: truck weighs ~3,800
unwashed, rust bucket and lots of tools behind the
seat. Those are also pretty good numbers but, now,
with the Saturn, I hope to use the Toyota only for
what it does best: hauling/mud and snow work.
Best I can do with an '86 Nissan EFI 4x4 is 25 mpg highway...in summer.
If the truck has not been maintained...such as lubed and tuned up...you can gain some there. I'd put a pint of water into the carb (slowly) to decarbon it...flush the oil with a pint of kerosene for 15 mins...advance the ignition some....lube the driveshafts...check the gear oil levels and / or replace....up the tire pressures.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
