Old 03-27-2008, 08:44 PM   #11 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by AD5OS View Post
Top engineer at Honda talking about Transmission fluid misconceptions.
I'm guessing 2 things from the video: 1) It relates mostly to manual transaxles (very few automatics in Japan); and 2) Sell more Genuine OEM Honda Transmission Fluid. V! Good link, tho...
Originally Posted by Red View Post
Tranny changes with oil changes, isnt that a bit much? Yes the tranny fluid does see more stress than engine oil, but, and I'm just thinking aloud here, tranny fluid would be build to withstand longer run times?
The purpose is to get the ratio of synth to regular as high as possible, since only about a 1/2 is drained with the plug method.
The proper way is to disconnect the lines from the radiator, identify the output and input lines, place the intake line in the bottle of fluid and the drain line into a disposal container. Then, have an assistant start the vehicle while you monitor the flushing process. When the output looks satisfactory, shut off the car and clamp the lines and re-install.
I didn't really have anyone around that weekend to help out and the plug came off pretty simply.
That's the reason for the quick-change interval. I'll also be able to inspect the magnetic plug to gauge any metallic wear issues.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
