Old 03-11-2010, 08:29 AM   #3 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Throttle-by-wire: Good for fuel economy
Throttle by wire, when executed properly, allows engineers to interpret the displacement of the go-pedal as a request for power, which could be filled in the most economical way possible.
Engines are usually efficient at low RPM and wide throttle aperature. With throttle-by-wire + CVT, the best scheme is probably to open the throttle wide, and vary engine RPM to give the driver the power he wants.
If you have a 4-speed auto, the best scheme is probably to keep it in the highest gear you can, with wide throttle angles but fairly lean air/fuel mix. If you press the pedal harder, the throttle should open farther. Once it's wide open, if the driver presses farther, downshift and close the throttle a little. This scheme requires a fast, smooth transmission, or the driver will complain that there's a huge lag between pressing the go-pedal and going.
The Aveo is highly optimized for low cost. It's not the best car in its class, and it doesn't represent what can be done with throttle-by-wire.
The Following 2 Users Say Thank You to RobertSmalls For This Useful Post:
Daox (03-11-2010), NeilBlanchard (03-11-2010)
