Do not be afraid to go up to the max tire pressure...not much ride difference between 42 and 44 psi. I have also found that those rim damaging chuck holes will often not damage a rim or tire when pumped up to the max...with less air pressure you bend a rim AND hurt a tire!
38 time NHRA/IHRA drag race champ
05 SRT4 / 12.17@117 mph on DOTs / 33.0 mpg
84 Horizon / 1760 lbs / 24 mpg
95 Neon / 46 mpg
2011 Prius / 62.1 without trying!
