Old 03-14-2010, 11:23 PM   #5 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
New tank for solar system
I am also working on a solar hot water system for my house.
For it, I will need a tank, heat exchanger, and pump. I already have a used 4'x10' collector that I bought last summer.
As for the tank, I picked up an electric water heater I was going to modify, but the more I looked at it, the less happy I was with the corrosion and threads/connections on it.
A neighbor was throwing out a 50 gallon steel pressure tank. It is in much better condition than the water heater. I realized that the tanks themselves are both the same size, so I cut off the insulation from the water heater to wrap the pressure tank with. You can read all the details about that HERE.
I'll still need to find a pump, coil copper pipe around the outside of the pressure tank for heat exchange, and tap into my existing water system, but the project is well on its way!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
