Old 03-28-2008, 07:32 AM   #120 (permalink)
s2man
I"m not lurking!
s2man's Avatar
Porthos - '96 Cavalier
90 day: 31.3 mpg (US)
Mine also came today - I got USB though. Which means I suppose it won't work with the Palm. Crud. I ordered mine before that particular direction was decided upon.
I ordered USB too, but assumed it will work with the Palm. USB to palm cables are like $6, and the serial.print function works on both RS232 and USB ports. Hope I'm correct. I also figured it would be useful for future expansion: USB to OBDII, USB memory sticks for data logging, etc.
Mine has only made it halfway across the country since Monday
Is everyone using straight system voltage to their boards? (12-14.5v) What I'm reading says to use 7-9v, and higher voltage may overheat the onboard power supply.
Roll on,
Stew
